| Home > Help Needed / General Tech Chat > Gear ratios, low rpm at 60mph? | |||||||
14 Posts Member #: 11782 Member Hawaii |
14th Aug, 2018 at 03:43:10pm
So I've been looking a lot at gear ratios and so on but nothing that will fit my build.
Edited by WillCarter on 14th Aug, 2018. |
14th Aug, 2018 at 11:12:17pm
What do you mean nothing that will fit your build?
15th Aug, 2018 at 06:45:53am
Thank you, the calculators a big help! Hadn't come across that before. |
257 Posts Member #: 11017 Senior Member Shropshire |
16th Aug, 2018 at 11:36:31am
2.9 or 2.7 but acceleration won't be as fun. |
16th Aug, 2018 at 06:27:08pm
I have a 3.1 final drive on 10"s, at 70mph I'm pretty much at 4K rpm. With the close ratio straight cuts first gear is a bit taller but no issues setting off even with the grippy clutch. I'm thinking about 2.9s as that will bring things down to 3.5k at 70mph. On 7th Nov, 2008 Nic said:
