Home > Help Needed / General Tech Chat > Banjo bolt 4 pots
Jordanmercer
Member #: 9716
Edenbridge, Kent
Iv got the hoses for the 4 pot conversion I just need the banjo bolt size to go through the other end of th return , does anyone know what size it is ?
Also different topic my mechanical fan catch’s on the engine is there different fans or should I just scrap it and go electric ?
Many thanks
jonny f
Member #: 9894
Dorking
There are various spacers to go between the fan and pump. Minispares sell them.
Electric fans never seem to be much cop on a side mounted rad in a mini.
t3gav
Member #: 229
Gavin@minispares.com
kent
You can't delete the mechanical fan! Use a small spacer if it's catching.
Jordanmercer
Member #: 9716
Edenbridge, Kent
Right thanks guys ordered one already!!
Any ideas on the banjo bolts ??
