| Home > Help Needed / General Tech Chat > Vented 4 pot pad retention - clips NLA? | |||||||
![]() 539 Posts Member #: 6807 Post Whore York |
9th Sep, 2018 at 12:54:36pm
Building up the vented Minispares four pots currently and I don’t have any pad retention clips, just the split pins.
Edited by adcyork on 9th Sep, 2018. |
10th Sep, 2018 at 11:34:39am
Yes you are correct they are NLA and not needed as confirmed by AP Braking :) |
10th Sep, 2018 at 12:46:01pm
Cheers Gav |
12th Sep, 2018 at 04:47:16am
There are loads of NOS metro brake fitting kits on ebay if you do want the retainers. |
![]() 112 Posts Member #: 10125 Advanced Member Zoetermeer, The Netherlands |
5th Nov, 2018 at 07:44:53pm
Carefull with those brake fitting kits. Many are for solid discs, especially the after market brands, that means the retention clips are a little smaller. I made that stupid mistake in the past and almost wrecked my mini in a tight rh corner at a hillclimb. Rear brakes locking up. The retention clips just slipped between the iron backings of the brake pads, so they worked like an extra spring to spread the pads when release brakes. I ditched these clips and never a problem again. |
