| Home > Help Needed / General Tech Chat > BMW K Head Throttle Body's and Plenum | |||||||
211 Posts Member #: 10890 Senior Member Twin Cam Turbo Build In Progress Rothwell, Northants |
23rd Sep, 2018 at 12:01:01pm
Hi Lads,
23rd Sep, 2018 at 10:38:40pm
I’d say at least 50% of us that have done the k1100 head conversion AND turbocharged it have used the plastic intake pieces.
Edited by turbodave16v on 23rd Sep, 2018. On 17th Nov, 2014 Tom Fenton said:
23rd Sep, 2018 at 11:13:18pm
I can give you (or anyone who wants it for their mini) the CAD for the bellmouth design if needed.
24th Sep, 2018 at 12:28:51am
I'd love a copy of the cad, I can give it to my nephew (CAD Designer) and get him to get them made for me. Do the bell mouths connect to the plastic inlet in my first pic above or the throttle body's in my second pic above. I think what Im trying to say is do I still use the K1100 throttle body's? |
24th Sep, 2018 at 04:15:37am
No. ITBs are simply not needed on a turbo setup; plenums with a single larger TB are simpler and well Proven.
Edited by turbodave16v on 24th Sep, 2018. On 17th Nov, 2014 Tom Fenton said:
24th Sep, 2018 at 10:31:33pm
On 24th Sep, 2018 TurboDave16V said:
No. ITBs are simply not needed on a turbo setup; plenums with a single larger TB are simpler and well Proven. If anyone wants it, send me a PM with your email address. So mind that my bellmouth was designed for use with 1/8” ally sheet; so you may want to tweak the thickness of the face that pokes through ever so slightly... I got some silicone straight tubing off fleabay (bought a whole meter of it) and use the original BMW clamps (although I cleaned and greased the threads and where the ends meet and slide when tightening - it all helps to put more clamp force on them, and I’ve not blown them off yet! There was a really neat method on the “project Binky” YouTube vids for cutting the silicone hose using a lathe that I plagiarized the last time I took my plenum off. |
24th Sep, 2018 at 10:38:52pm
My TB is a unit off a VW 1.8t but it’s DBW so not compatible with every ECU.
25th Sep, 2018 at 10:02:28pm
My TB is a unit off a VW 1.8t but it’s DBW so not compatible with every ECU. Jimbo does the same as me with the hoses and he’s run crazy big boost (26+)? IIRC |
