| Home > Help Needed / General Tech Chat > Valve tip grinding Northants area | |||||||
211 Posts Member #: 10890 Senior Member Twin Cam Turbo Build In Progress Rothwell, Northants |
3rd Oct, 2018 at 06:05:44pm
Hi Aal, just had my valve seats done and I basically need to replace all of my cam followers. Instead of replacing them I’m thinking about getting the valve tips ground down by about 0.25mm The amount varies per valve bu roughly that amount. Does anyone know of anyone in the Northants area that has or can do this? |
5th Oct, 2018 at 10:13:22am
This is just my thoughts so take it as you wish, but I have done this in the past when setting up solid lifter heads I just used a well dressed grinding wheel and knock the head off the stem till its correct. only tools required is something to measure valve legnth fairly accurately, a bench grinder, and if your particularly fussy a wee jig to hold the valve perpendicular to the side of the wheel (I use the side of the wheel rather than the face for this job) .. im not saying its the way to do it, but its how I do it and it seems to work.
7th Oct, 2018 at 08:43:07pm
Might be worth having a word with Specialist Components, or Brett Sims Motorsport to see if you could send them to them for grinding to length. It wouldn't be a large parcel. Edited by minimole23 on 7th Oct, 2018. On 7th Oct, 2010 5haneJ said:
