| Home > Help Needed / General Tech Chat > Setting ignition on dyno | |||||||
113 Posts Member #: 11786 Advanced Member |
11th Oct, 2018 at 03:42:41pm
Hy all, since my car is running now quite ok and i have few miles on it, i want to get it set up properly on a dyno.
11th Oct, 2018 at 07:40:39pm
Pinking is too late really and isn’t the ideal strategy, but you do need to still listen for it.
Edited by turbodave16v on 11th Oct, 2018. On 17th Nov, 2014 Tom Fenton said:
11th Oct, 2018 at 07:47:16pm
Btw, we’ve a few guys here play on rolling roads quite frequently, and hopefully will also chime in - and hopefully correct anything I got wrong above! On 17th Nov, 2014 Tom Fenton said:
11th Oct, 2018 at 09:27:09pm
Always avoid knock/detonation...simple.
11th Oct, 2018 at 09:28:36pm
Pinking really only apply to part throttle cruise, if you try to do that on any decent boost level then your going to get detonation and somthing will break.
15th Oct, 2018 at 08:31:11am
That last comment chimes with me because I think it is very difficult to detect detonation by ear and it will often be too late anyway.
15th Oct, 2018 at 10:36:38pm
Think of MBT as the point at which the best torque is achieved for the least ignition advance. When you are far from MBT, 1 or 2 degrees change in advance usually sees a respectable increase in torque. When 1 or 2 degrees increase of advance results in little or no change in torque, you are at or near MBT.
16th Oct, 2018 at 11:34:55pm
On 15th Oct, 2018 tadge44 said:
That last comment chimes with me because I think it is very difficult to detect detonation by ear and it will often be too late anyway. Pick a dyno operator who understands A series and has det cans at least. No it isnt. With det cans, any competent operator will be able to hear it before there is any risk whatsoever to the engine. If you're simply trying to listen sitting in the car with your ears over all other noise...then yes, anything you can hear..is already highly damaging to the engine. 9.85 @ 145mph
20th Oct, 2018 at 08:30:25pm
Agreed.
