Home > Help Needed / General Tech Chat > Plenum repair (snapped vacuum connection)
Will
Member #: 11091
I’ve got a plenum and somehow the small air vacuum connection on (3mm?) has snapped off
It’s the standard gonzo metro turbo plenum
What would be the best way to get this repaired?
Drill and tap a barbed connector? Or should I send it off to a specialist?
Thanks for your help guys
Drill and tap 1/8 NPT
Done
I agree with the above, drill and tap and fit a new barb. Or if you are really stuck and can't do it yourself, I could sort it for you.
