Page: |
Home > Help Needed / General Tech Chat > | |||||||
167 Posts Member #: 11091 Advanced Member |
15th Nov, 2018 at 02:32:39pm
On 14th Nov, 2018 Turbo Phil said:
The MPI head casting is much thicker in the area where the alternator bolts on, plus you've got the temp sensor hole right in the way on a non MPI head casting. I've plenty of MPI heads if you need one mate. Phil. Thanks, trouble is I’ve got the bigger flower valves and all the nice bits on this head etc :( How much would I be looking at getting the bigger valves and compression ratio dropped on an mpi casting? On 14th Nov, 2018 shane said:
This was my resolve for using the Mpi block and mounting a denso. Shane that lower alternator mount is beautiful, probably a lot to ask but any chance of another! Haha! Where you running a front mount radiator? Edited by Will on 15th Nov, 2018. |
Page: |
