Home > Help Needed / General Tech Chat > Boost pressure depending on ignition timing?
JackZwiebel
Member #: 11786
Hallo,
i have finally set my ignition up correctly and the engine is running just fine now. The fueling seems correct over the whole rpm range and its running on 4 psi boost.
What makes me think is following: i did a testdrive befor with timing way to soon and i had a boost pressure of 10psi there.
I thought the turbo should work better the more i retard the ignition, since more heat gets to the turbine. Also the maximum boost should be limited by the wastegate and therefore not change with the ignition timing.
I have the wastegate actuator directly connected to the plenum chamber.
So is this normal or should i look for leaks?
dont think of the drive for the turbo as heat, or pressure, its energy, so a combination of the two,
generally available turbo drive goes hand in hand with how much fuel is being burnt (efficiently), although there is the old antilag trich of dumping in a rich mixture and retarding, but thats a very extreme situation.
all that aside, yes the wastgate sets the boost, and it should not change with timing once at wasegate level, check for leaks, or a dodgy actuator, or stiff linkage.
JackZwiebel
Member #: 11786
Thanks, im going to check for leaks then.
Excessive levels of retard will causes very high EGT's and lead to problems and potential damage.
Run the correct/optimal levels of timing that the engine wants.
JackZwiebel
Member #: 11786
Yeah i am running at the factory settings of the metro turbo now, using the 65dm4 distributor from the metro turbo. Might not be the optimal setting for performance but should be save to run and the engine runs well in all fields.
