Home > Help Needed / General Tech Chat > runnin on
Carl
Member #: 95
liverpool-on-sea
could ne1 tell me if its normal for a turbod mini to run on after turning off the ignition when its hot?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Fairly on all A-series...
thats why metro's have an anti-run-on valve that dumps all the vacume in the inlet manifold :)
alex
AlexF
minster
Member #: 198
Im no expert but are you running spark plugs with the correct heat range, if youve raised the boost etc you might need colder plugs, speak to a rolling road operator, theyd be able to help
