| Home > Help Needed / General Tech Chat > gearbox advice | |||||||
81 Posts Member #: 11548 Advanced Member Calne Wiltshire |
9th Mar, 2019 at 09:06:08pm
Hi all I thought I had it all sussed out what way to go with my gearbox slowly building up a 1098 engine hoping to get about 130bhp out of it .So from reading old posts would just about be ok to use helical gears but have been saving my pennies and am thinking of getting minispares clubman straight cut set and keeping helical drops to keep the noise down.Was going to also buy a minispares rebuild kit with the evolution baulk rings but am now confused by old posts saying use genuine rover or old 2nd hand ones .I have only driven the car about 10 miles and 2nd gear was a bit crunchy.As always grateful for any advice. Thanks Pete |
![]() 112 Posts Member #: 10125 Advanced Member Zoetermeer, The Netherlands |
9th Mar, 2019 at 10:19:22pm
I did a rebuild of a gearbox some time ago, used the evo baulk rings for 10.000 km now. Not normal traffic but bad boys rally and hillclimbing. No troubles so far.
10th Mar, 2019 at 09:24:07am
The advice varies because the quality of the rings available has varied. If you are buying the Evo helical headset from Minispares, I’d ask them which baulk rings to use - I’m guessing it’ll be their evo vault rings.
In the 13's at last!.. Just |
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
10th Mar, 2019 at 10:25:14pm
On 10th Mar, 2019 theoneeyedlizard said:
The advice varies because the quality of the rings available has varied. If you are buying the Evo helical headset from Minispares, I’d ask them which baulk rings to use - I’m guessing it’ll be their evo vault rings. When I bought my SC Evo gearset, I fitted used genuine baulk rings. These didn’t last very long before I got a crunchy 2nd. I’ve now fitted the MS Evo rings hoping for a bit more life from them. |
10th Mar, 2019 at 10:25:18pm
13th Mar, 2019 at 10:59:14am
We no longer stock 'genuine' baulk rings... |
