Home > Help Needed / General Tech Chat > K1100 breather setup
Shiner
Member #: 6004
Portsmouth
Looking for some help with the K1100 breather setup.
I have the SC breather block at the fuel pump location that has a breather pipe outlet, another breather outlet on the head end plate above the oil drain and also another breather on the back of the cam cover.
Where do they all go. I have searched and found people mentioning catch cans etc - would these count as a breather as I just imagined it being something like a K&N filter?
I know my old engine had a tank on the transfer box but looking at my one now, I have the flange for this tank but the hole leads to a dead end...
Any help appreciated
Thanks
Shiner
Member #: 6004
Portsmouth
Ok, a little correction. Just had another look at the transfer case hole and whilst it doesnt look to have an opening to let the engine breath, I tried giving it the kiss of life and tried blowing into it and its not a dead end.
Air is going in somewhere but cant feel an opening whilst feeling inside with my finger.
On a separate note, could I also use this as a means to fill the engine up with oil?
shane
Member #: 1246
Lowestoft, Suffolk.
Edited by shane on 14th Mar, 2019.
shane
Member #: 1246
Lowestoft, Suffolk.
Right hope this makes it easier to see/understand what I’ve tried to achieve.
The black breather block I made originally with 2x 1/2” barbs to which I was going to vent.
This has been replaced with another block I made minus the two 1/2” ports.
The drain from the head has now been extended toward the clutch housing where it will meet with the vent from the housing up to a baffled separator / breather tank.
I’ve purposely not taken off the rocker as the theory (I believe it was Slater) that venting off the crankcase well enough would allow any positive pressure in the head to vent to the crankcase via the drains.
If this proves poor in practice I’ve left sufficient space to add vents from the rocker.
Shane.
Edited by shane on 15th Mar, 2019.
Kean
Member #: 341
aka T2clubby
South Staffs
That looks bloody tidy Shane
shane
Member #: 1246
Lowestoft, Suffolk.
Thanks Kean, the whole build has been made 3 times.
Shane
Shane
I am looking forward to getting started on my 16v now tbh.
shane
Member #: 1246
Lowestoft, Suffolk.
I’ll be glad to get it finished, 10 years is taking the p@@s now.
It would of been less but my OCD hasn’t helped.
Shane
Shane
Shiner
Member #: 6004
Portsmouth
Thanks Shane for your help and explanation.
Just so I can understand, you have run the drain from the head to the block mounted at the fuel pump location and then T'd it off and extended it to a separate breather catch tank which also the crankcase breather goes to?
This sounds achievable, although making that catch tank would be difficult with my welding skills, can I just leave it in cardboard form *happy*
Thanks
shane
Member #: 1246
Lowestoft, Suffolk.
Not a problem,
Yes, if you look at the first photo of the rear of the engine this is pretty much what I have ended up with. But the 25mm tube has now been extended to where the clutch housing breather is. Two hoses will then go up to the separator/breather tank.
I’m afraid I haven’t any current pictures of the rear of the engine with the latest revision, hence the multiple images and poor description.
Found another pic showing where the extended tube now runs too, I hope that adds some clarity.
Thanks
Shane.
Shiner
Member #: 6004
Portsmouth
Perfect, makes sense. Thank you again.
Nice build by the way.
shane
Member #: 1246
Lowestoft, Suffolk.
Thanks,
Re oil filling I’ve p@@sed around with a few ideas over the years but not really got a definitive yet.
My favored option was a caninableised breather can with a filler on top (similar to what SC sell) but space ruled otherwise.
I then faffed with a filler that drained in to a core plug for the oil gallery on the head between the cam’s. Aesthetically it was nice but made doing anything with the leads a pain, it may of been ok if using coil on plug.
Again hopefully picture explain better.
Shane
slater
Member #: 1291
Suffolk / Birmingham
The block they sell that goes on the fuel pump hole is for the oil drains from the head. You dont want to breath from there as there's too much oil flying about.
Simply take a large breather from the transfer housing and a small one from the top breather outlet on the end of the head. Noting else is needed.
You can also fill oil though the transfer housing. By far the neatest solution.
Shiner
Member #: 6004
Portsmouth
Could you fill with oil through the dizzy hole or is that hard to get to. Been ages since I've seen my engine in the mini itself?
If going down the route of modifying a breather can to use as a filler on the transfer housing would you 't' in to the pipe to run a breather to it also?
shane
Member #: 1246
Lowestoft, Suffolk.
I can see that, but that said there has been previous comment on here within other breather related threads that there is a lot of oil flying about around the transfer case breather with the drop gears located below, also I think it was Joe C mentioned once that a lot of oil gets flung out of the dizzy hole if open with the engine running but that hasn’t stopped people using either as breather point successfully.
The advantage you have here is you have a car that’s running and a breather system that dare I say is proven.
I think I saw once on here that someone did use the dizzy hole as an oil filler, but this obviously takes up space at the front of the engine bay that could be used better. I agree with Slater the transfer housing is the neatest option.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=610404 Interesting read.
Shane
