| Home > Help Needed / General Tech Chat > Fuel pump voltage? and some serious flooding | |||||||
26 Posts Member #: 1798 Member Ratingen (Germany) |
16th Mar, 2019 at 05:39:11pm
Good day to all |
16th Mar, 2019 at 07:18:38pm
Fuel pump should not be an issue,
16th Mar, 2019 at 07:35:25pm
Most likely some dirt has stuck the needle valve open.
18th Mar, 2019 at 10:13:30am
Unless your replacement pump flows too much for the regulator to handle and the carb is getting a million psi.
In the 13's at last!.. Just |
18th Mar, 2019 at 12:31:39pm
Many thanks for the replys, will take out the carb and measure the preasure from the regulator...normally what ever is going wrong must be easy to find as never did i see a cylinder full of fuel... |
1st Apr, 2019 at 08:11:43pm
Did you empty the carb before you stored the car? if not as mentioned above you will have a poorly seating float valve due to residue left behind. Own the day
