Done a bit this afternoon.
Put the rocker cover on to make it look nicer, haha:
Untitled by Bryn Kinsman, on Flickr
Not got a picture but changed the clutch slave cylinder thing and hose:
Started to lay out the megajolt wiring:
And also set about changing the wiring for the pre engaged starter motor, im using the original solenoid as a relay as has been advised, ive put both the battery feed and feed to the starter motor on the same terminal but thats as far as ive got as im confused:
The wire colours dont seem to match what everyone has said online:
