| Home > Help Needed / General Tech Chat > Ignition Relay | |||||||
21 Posts Member #: 11807 Member |
14th Apr, 2019 at 09:43:17pm
Hi, just fired up my project for the first time, supercharged 998.
15th Apr, 2019 at 11:30:47am
Without seeing your modified wiring in diagram form, I can't be 100% certain but it is very likely to be a backfeed through the charging light circuit especially if the relay you have used has a nice high operating coil resistance (ie, if it only takes a few milli-amps to hold it latched).
15th Apr, 2019 at 11:39:17am
Thanks, pretty sure its feeding back and energised still, will try direct off switch, and if still does it, I'll take dash out and remove bulb which should break circuit and see if problem and if so rectify with a diode. |
16th Apr, 2019 at 08:08:38pm
Relay linked out and still runs on, but if alternator unplugged it cuts with key immediately, so ordered up some diodes and will fit along with wiring the rev counter. Cheers |
