| Home > Help Needed / General Tech Chat > 1275 with a blower | |||||||
40 Posts Member #: 11872 Member aberdeen |
18th Apr, 2019 at 05:36:24pm
Alright chaps,
20th Apr, 2019 at 01:48:29pm
The number you quoted above (12ha08aa) is not a turbo engine, and no 1.3 Metro had the 3.1 iirc.
Edited by turbodave16v on 20th Apr, 2019. On 17th Nov, 2014 Tom Fenton said:
20th Apr, 2019 at 09:33:12pm
Spending a couple hours checking what the engine number where online, that was the only information i could find! I Started to get the engine ready for removal from the bay and i doubled checking the head numbers. I'm pretty sure now it's not a turbo head just a normal 12g940. (Must of been wishful thinking)
Edited by Struanbedgar on 20th Apr, 2019. |
21st Apr, 2019 at 05:45:42pm
chances are it'll need a rebore or at least a hone, do you have access to a bore gauge? if you can get away with a hone you can use total seal rings on the std turbo pistons, (if thats what you have)
21st Apr, 2019 at 08:16:09pm
Yeah lucky enough to get my hands on a bore gauge.
21st Apr, 2019 at 08:43:05pm
well fisrst thing is see how the bores measure up, if theres wear ( and that pretty likly) then you'll be looking at a rebore to +20 so new pistons, and if your getting new pistons, then see what you can get in cc options, often the lager dishes are only in forged versions, so depends on your budget, depends if you can stretch to the 500 quid for a forged set, basically your options are 10cc cast, or 18cc forged.
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
21st Apr, 2019 at 10:36:52pm
On 21st Apr, 2019 Joe C said:
turbo phil on here is a great head guy, and reasonable prices too. |
22nd Apr, 2019 at 05:54:31pm
22nd Apr, 2019 at 07:26:04pm
Started stripping the motor for inspection today.
19th Jul, 2019 at 04:17:54pm
Well finally got some time to fully strip the engine.
19th Jul, 2019 at 05:43:00pm
Hard to tell you what pistons they are from that description.
19th Jul, 2019 at 06:13:13pm
When both pistons are side by side the piston rings line up, piston hieght is the exact same and the cc are the same ECT the only difference is the skirt.
