| Home > Help Needed / General Tech Chat > Small bore - Con-rod locking tabs | |||||||
3rd May, 2019 at 12:11:16pm
I'm just building a 60s 1098 Midget engine.
3rd May, 2019 at 08:36:38pm
I ordered a set when I built my 1060. They were softer than cheese, I thought there was more risk of the bolt eating into them and they working loose. So I never used them. I did buy a set of ARP bolts as they were cheap.
3rd May, 2019 at 10:30:28pm
Can you change the rods for A+ type with bolts? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
4th May, 2019 at 02:16:40pm
Thanks guys.
On 3rd May, 2019 gr4h4m said:
I ordered a set when I built my 1060. They were softer than cheese, I thought there was more risk of the bolt eating into them and they working loose. So I never used them. That's my point really I suppose. On 3rd May, 2019 wil_h said:
Can you change the rods for A+ type with bolts? A bit of research has shown that the only big difference between the A-Series rod and the A+ rod is the bolt. The A+ bolts are specifically designed not to require tabs. I read them as described as "stretch" bolts, so I'm guessing they are less prone to coming loose if they have less give. I've got a spare set of once used A+ rod bolts, so I'm going to pop them in. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
4th May, 2019 at 03:09:09pm
I suppose the originals worked great for many years, but the reservation id have is already covered in that you’ve no idea what the original matl spec was and no idea that what you buy is a suitable equivalent.
67 Posts Member #: 8956 Advanced Member Algarve/Portugal |
4th May, 2019 at 11:31:01pm
I never use the tabs neither the pre A bolts, only A+ bolts or 12.9 Allen. |
7th May, 2019 at 02:59:23pm
I've always used 12.9s with a bit of thread lock. That or ARP gear |
5th Feb, 2020 at 10:47:21pm
