Page: |
Home > Help Needed / General Tech Chat > Compression lost on cylinder one | |||||||
238 Posts Member #: 11017 Senior Member Shropshire |
18th Jun, 2019 at 06:26:51pm
Hi guys,
Edited by Steve220 on 20th Jun, 2019. |
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
18th Jun, 2019 at 06:42:41pm
Not welcome suggestion but you need to look at that piston and it,s rings. May be that the ring lands are compressed, trapping the rings |
18th Jun, 2019 at 06:47:13pm
Rich on inners and lean on outers. Poor fuel distribution.
2091 Posts Member #: 9894 Post Whore Dorking |
18th Jun, 2019 at 09:19:59pm
I would say you need to get that piston out and have a look. Could be a broken ringland which might not damage the bore.
On 18th Jun, 2019 Paul S said:
Rich on inners and lean on outers. Poor fuel distribution. Check the exhaust valve before digging deeper would be my advice. Not sure if you missed it Paul but he says it is smoking out the breathers and fairly heavily. Would of thought that could only mean one thing? |
19th Jun, 2019 at 09:15:01am
Only quickly skimmed the pictures.
19th Jun, 2019 at 09:37:39am
On 19th Jun, 2019 Paul S said:
Only quickly skimmed the pictures. The bore damage looks like it could be caused by debri. Is that exhaust valve even sitting on its seat? Hi Paul, Will check today. Thanks for the input guys, as you can imagine, i'm a little gutted by all this. |
6743 Posts Member #: 828 Post Whore uranus |
19th Jun, 2019 at 10:34:30am
quickly put the head on its side and full the ports with petrol., Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
19th Jun, 2019 at 10:58:03am
Hi all,
19th Jun, 2019 at 11:07:31am
On 19th Jun, 2019 robert said:
quickly put the head on its side and full the ports with petrol., it weeps out of the exhaust valve |
19th Jun, 2019 at 11:57:42am
that could be it then, roll ithe stem on the desk to check it not bent, if not touch it back on the seat with some pase and try the petrol test again. also check the valve waggle in the guide. On 28th Aug, 2011 Kean said:
19th Jun, 2019 at 12:08:03pm
On 19th Jun, 2019 Joe C said:
that could be it then, roll ithe stem on the desk to check it not bent, if not touch it back on the seat with some pase and try the petrol test again. also check the valve waggle in the guide. Joe, do you mean paste as in lapping paste? |
4619 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
19th Jun, 2019 at 12:10:36pm
Do as Joe suggests. Are there any contact marks on the piston head ?
19th Jun, 2019 at 12:30:52pm
Stem of valve is straight, no contact marks on the piston crowns either. |
19th Jun, 2019 at 12:50:01pm
Just lapped the valve in and its still leaking fuel |
19th Jun, 2019 at 01:18:43pm
Cleaned the pistons up and there's no damaged to them at all, no traces of det either. If its just the valve, whats causing the smoke from the vents? |
19th Jun, 2019 at 02:01:31pm
Check the seat on the valve. Has the paste cleaned it up all round? If not it would suggest the valve is bent.
19th Jun, 2019 at 02:22:16pm
A lot at idle, under boost it didn't seem that much. When driving home from the rolling road, when i came to a stand still, it was like a smoke machine. But it didn't smell of oil and it was white. |
19th Jun, 2019 at 02:29:19pm
Smoke from the breathers or exhaust?
19th Jun, 2019 at 02:35:14pm
Smoke from the breathers or exhaust? White smoke is usually steam from coolant. Is the coolant level OK? From the breathers. Exhaust was fine, no smoke. Coolant ekvel was slightly slower than usual when I got back, nothing concerning. |
19th Jun, 2019 at 02:52:40pm
hmm , maybe drain oil , and put all pistons level , and pop an inch of diesel or petrol on them and see if the duff cylinder dissapears faster . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
19th Jun, 2019 at 03:37:50pm
hmm , maybe drain oil , and put all pistons level , and pop an inch of diesel or petrol on them and see if the duff cylinder dissapears faster . Not a bad idea! About to pull the engine now. |
19th Jun, 2019 at 08:18:42pm
And there we go. Piston 1 & 3 have cracked ringlands
7259 Posts Member #: 1268 The Boom Boom speaker Police! Essex |
19th Jun, 2019 at 09:36:18pm
Ouch!
In the 13's at last!.. Just |
19th Jun, 2019 at 09:41:38pm
That’s a bugger that two have gone. You can sort it though.
19th Jun, 2019 at 09:54:49pm
On 19th Jun, 2019 jonny f said:
That’s a bugger that two have gone. You can sort it though. What were ring gaps? Perhaps gone tight. I am no expert though! I'm beginning to think it could be that and running hot! These were my gaps |
Page: |
