Home > Help Needed / General Tech Chat > Piston identification
fester
Member #: 674
Gympie, Qld Australia
Guys until I can find my measuring sticks can you help me with the pistons in this engine I bought.
They are turbo pistons (20831) but what marking denotes standard or overbores. The only other marks are an "A" in the middle of the piston top and also cast into the underside and along the top outside edge next to the part number is what looks like 1D7 or 107 ie 20831 1D7
I"m assuming they are oversize only because I supect the motor to be rebuilt otherwise someone was very religious with oil changes as the block and head are as clean as a whistle, no burnt or old oil stains at all. Also the engine number plate is gone and the number is stamped on which means at least the block has been skimmed.
Gavin
Dangerous
Member #: 417
the A is just the grade,you gt A and B engines new
Doodmeister
Member #: 149
Alberta, Canada
At a guess +0.20 on the piston crown would denote oversize pistons.
Oversize Pistons are Very obvious from the markings as Doody commented. If it don't say it, they're stock.
Amp
Member #: 7856
Bit of a thread excavation but it was the only thread I could find that referenced it!
My question; does anyone know what the "A" or "B" stamped into the crown on the 20831 pistons represents exactly?
I think, it's the accuracy of the machined piston, and they would use either A or B depending upon the accuracy of the machined block, so they mix and match for best fit. But don't quote me on that.
