Home > Help Needed / General Tech Chat > Rod's
Kean
Member #: 341
aka T2clubby
South Staffs
Do the con rod bolts just drift out or is it best to use a bit of heat?
And does anyone know the recommened torque setting for arp rod bolts?
cheers.
Punch them carefully out. No heat required. Remeber to have them resized when fitting new ones. They do change.
Doodmeister
Member #: 149
Alberta, Canada
http://www.aptfast.com/ARP_Additional_Stuf...arp_t_specs.htm
Look at BEB-1 for std a+ rods
Vegard, Resize what the rod bolts ??
Edited by Doodmeister on 1st Oct, 2005.
Dangerous
Member #: 417
I use the hole end of a 3/8 extension bar and tap them out
When putting them in make sure they are the right way round and seated properly
I was thinking of resizing the rods really *wink*
Doodmeister
Member #: 149
Alberta, Canada
A tad unnecessary for a road smoker unless it's had bearing failure in the past causing the rods to go oval.
But I can see where you’re coming from if you've got the time and cash at hand then it's a good move for peace of mind.
Kean
Member #: 341
aka T2clubby
South Staffs
Cheers guys, excellent advice as usual. :)
On A+ rods I'd definately do it as these are made of chocolate ( hot chokolate I might add, the type that has been lying in the sun)
On old A rods it's not "that" necessary.
A+ rods are really bad for getting oval compared to the older (heavier) stuff.
No, they're not chocolate. They're made from Sponge Cake, definately......... *tongue*
i take it cooper s rods are stronger than kiplings fineist?
bakewells or apple pies?
custard and apple pies
