Home > Help Needed / General Tech Chat > Heater unit removal/bypass
Mickyclark87
Member #: 11796
Seen some people have completely removed the incar heater unit and bypassed it all together. I want to do the same, couple questions,
Apart from heating the inside up (when they work) any advantages or disadvantages to removing.
is it a case of removing the heater and linking the two pipes together
Do I need to extend the pipes to make up for loss of coolant that would of been filled up in the matrix.
Thanks micky
I simply removed mine and linked the two pipes.
You’re losing extra water capacity from the cooling system, so if your current cooling is marginal removing it won’t help matters.
Phil.
Mickyclark87
Member #: 11796
Great
Thanks again phil
I’ll give it a go and keep an eye on temperature
D4VE
Member #: 10749
lowestoft suffolk
Depending on your set up, i brought a rad hose without the take off and blanked off the head (dry decked anyway) so have no unsightly hoses doing nowt!
Nothing gets past Dave lol
Downsides ?
No heater, and no means to clear the windscreen ( even if it isnt great anyway lol )
IMO given how little it weighs in a Mini...I can see few benefits to removing it.
Yo-Han
Member #: 3228
North of the Netherlands
No sure what the car is used for but IIRC here in the Nethererlands we need a blower / demister in for the Dutch equivalent of MOT...
(Eventhough it only blows air on the windscreen rubber)
Dazed and Confused....
slater
Member #: 1291
Suffolk / Birmingham
Heated windscreen is the way forward if you remove the heater.
