| Home > Help Needed / General Tech Chat > Trailer tie downs | |||||||
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
17th Oct, 2019 at 11:27:09pm
I’m looking at replacing my ratchet tie downs for my car transporter/trailer.
18th Oct, 2019 at 08:01:56am
If you look on eBay there are companies that do ‘recovery’ sets. I got one of these to make me a custom set in 38mm (rather than 50) and with the wheel straps a shorter length to suit Mini wheels. |
18th Oct, 2019 at 08:43:18am
Thanks Graeme,
18th Oct, 2019 at 09:08:18am
I've used Damar Webbing Products in Chesterfield, helpful and manufacture themselves so within reason you can have what you want.
18th Oct, 2019 at 01:38:14pm
Thanks Tom, is that the same for the chokes with the “protective” webbing pads attached?
Edited by shane on 18th Oct, 2019. |
18th Oct, 2019 at 05:46:10pm
Yes the protective pads aren’t much use either. Get the soft loop wheel straps.
![]() 539 Posts Member #: 6807 Post Whore York |
20th Oct, 2019 at 10:18:40am
You need to make sure to get the right length link straps. I bought the set in the link below last week and they’re ideal. The metal d ring sits on the tyre so no rim damage and I couldn’t find any cheaper.
20th Oct, 2019 at 09:06:24pm
I did look at those and similar but felt the 14” link straps were too long.
21st Oct, 2019 at 12:00:05am
On 20th Oct, 2019 shane said:
I did look at those and similar but felt the 14” link straps were too long. I contacted Damar webbing as per Tom’s recommendation and they are manufacturing me a set of short ones, and at only £4 each plus postage. Shane That's good to know |
21st Oct, 2019 at 08:39:06am
Now that name has been mentioned, I think mine are Damar too.
21st Oct, 2019 at 08:56:34am
On 20th Oct, 2019 adcyork said:
The metal d ring sits on the tyre so no rim damage and I couldn’t find any cheaper. Hopefully they will work for you, I only damaged a wheels paint with them once before I threw the fuckers in the bin.
21st Oct, 2019 at 01:12:14pm
You can just buy the bits separately. The straps are just straps and the links are just 1 ton endless slings.
