Partition you drive is a piece of piss Shane, you've got all the software you need already.
Look in. your utilities folder, in your application folder, find and launch 'Disk Utility'.
Once it's launched you'll see in the application window at the left hand side all your hard drive. Select it then at the top of the window you'll see the 'Partition' button. Click on that and you'll get a image of your hard drive (like a pie chart) adjust that to the size you want you new hard drives to be. You'll also see a drop down menu called format, you need to change this to MS-DOT (FAT) if your portion is 32GB's or less, if it's larger than 32GB's you need to set it to ExFat and than click apply. A few minutes later you'll have effectively 2 hard drives.
Then you can install any version of Windows on that partition. If you don't know anyone with a copy you can borrow, there's always everybody's favourite torrent site pirate bay.
