| Home > Help Needed / General Tech Chat > Edis connections | |||||||
24 Posts Member #: 11891 Member |
12th Jan, 2020 at 10:53:01am
Now the rat is starting to come together we have a clutch, gears & the timing is correct for a base line, i need to tidy up the wiring & the edis module that I obtained has only wiring tails of about 10mm enough to get a faston correction but not enough to use a back seals Saab type for a perminant weathered connection. The question is does anybody know the pins that are used in the edis module if they are available or can you get the mail connector on its own , been searching & can't find anything. |
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
12th Jan, 2020 at 12:58:19pm
Have you a pinning tool to disassemble the plug to see what the pins are?
81 Posts Member #: 11548 Advanced Member Calne Wiltshire |
12th Jan, 2020 at 04:22:51pm
https://trigger-wheels.com/store/contents/en-uk/p190.html looks like trigger wheels have them not cheap though |
12th Jan, 2020 at 09:06:53pm
Spotted the connector on trigger wheels site , bit shocked at the price & not sure if they have the pins or it's a bare block , I'll drop them a mail to find out., I have two to rewire one on the rat & one for a future build. I will get the relevant removal tool when we can identify what the pins are. |
12th Jan, 2020 at 10:57:13pm
On 12th Jan, 2020 Dexter said:
Spotted the connector on trigger wheels site , bit shocked at the price & not sure if they have the pins or it's a bare block , I'll drop them a mail to find out., I have two to rewire one on the rat & one for a future build. I will get the relevant removal tool when we can identify what the pins are. Shane |
174 Posts Member #: 9128 Advanced Member |
12th Jan, 2020 at 11:13:10pm
You can get the connectors out with a small flat screwdriver.
12th Jan, 2020 at 11:39:18pm
http://thumbsnap.com/ezTLb2ue according something I've found on piston heads you used to be able to buy terminals from ford dealers |
13th Jan, 2020 at 12:13:41am
I was going to call in my local ford dealer & see if they can assist, not that I have much hope but you never know. Now I've got the rat running , I don't want to disturb anything until I can make a loom up test it on the bench then fit. |
