| Home > Help Needed / General Tech Chat > Metro turbo spaced manifold washers | |||||||
167 Posts Member #: 11091 Advanced Member |
16th Feb, 2020 at 01:17:19pm
Do all metro turbos come with stepped manifold washers? If so where and you get them back getting a grinder out?
16th Feb, 2020 at 01:21:39pm
Answered my own question
18th Feb, 2020 at 02:50:41pm
Yes. The inlet and exhaust manifolds are the same thickness. In the 13's at last!.. Just |
264 Posts Member #: 11029 Senior Member Crewe |
19th Feb, 2020 at 01:59:54am
My fusion fabs manifold came with some stepped washers but I still had to get the power file out and the grinder to make both manifolds fit flush without side loading the stud. I'm using an original turbo inlet and fusions exhaust manifold. Outside the box |
19th Feb, 2020 at 10:37:51am
I just cut the inlet to suit. Looks a bit rough someone had been at with a hack saw |
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
19th Feb, 2020 at 02:48:32pm
I'm using a Matty exhaust and NA metro inlet.
'Where does the engine go?' |
20th Feb, 2020 at 01:22:50pm
I found with both Metro manifolds it was still necessary to make stepped washers and eventually did as Steve describes above as well. |
