Home > Help Needed / General Tech Chat > Gt1752 water pipes
nibble36
Member #: 4273
stoke on trent
Hi all I'm Just rebuilding my engine and upgrading to a gt1752 from the T3
, where is the best place to take the water feed from for the turbo, was thinking about the heater out let on the head and back in the other side,
Amy help or pics would be great thanks nibble36
I have mine setup this way. There are better ways of doing it, but this is probably the most simple.
tadge44
Member #: 2500
Buckinghamshire
I drilled a waterway at the back of the block and returned to a stub on the rad header tanks, as many others have done
hazpalmer
Member #: 9038
Carlisle, Cumbria
Mines out the head, and back into the bottom hose.
steve1275
Member #: 951
Bromsgrove
As above, I also put a small electric water pump in this circuit run off a timer so it stays on for a few minutes after shutdown,to help with turbo heatsoak.
'Where does the engine go?'
