| Home > Help Needed / General Tech Chat > locking 2 gears together??? | |||||||
2nd Oct, 2005 at 02:35:18pm
i'm in the middle of changing my CW&P, just got to the stage now where i need to lock 2 gears together to undo the pinion nut. On 20th Oct, 2015 Tom Fenton said:
2nd Oct, 2005 at 02:44:40pm
i've had a search and all i can really find is how to get the nut undone :(
2nd Oct, 2005 at 03:15:07pm
pull the selector out completely...
AlexF |
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
2nd Oct, 2005 at 04:20:10pm
not done this myself as yet, but a chap at work was stuggling with the same thing and he phoned a gearbox specialist and they said to drop in a nice thick oily rag to lock it out!! |
![]() 2641 Posts Member #: 19 Post Whore newcastle |
2nd Oct, 2005 at 04:27:08pm
then try an get the rag out ???
2nd Oct, 2005 at 06:00:04pm
Dont forget to remove the sleeve that is around the spring/ball bearing thing.Then get a bit of wood and whack both nd gears outwards
2nd Oct, 2005 at 06:34:44pm
You dont need to whack the selectors and risk damaging them to get it in gear.
2nd Oct, 2005 at 06:35:04pm
I damaged a tooth on a box using the rag method... |
2nd Oct, 2005 at 08:38:49pm
cheers dudes. i've managed to lock the 2 gears together now. haven't removed the ball and cup just the spring, is this gonna cause me any problems?
2nd Oct, 2005 at 08:40:41pm
the windy gun just chips teeth!
AlexF |
3rd Oct, 2005 at 07:11:38am
On 02/10/2005 18:35:04 SumpNut said:
I damaged a tooth on a box using the rag method... And spread the laygear from the mainshaft bending stuff.. BAD IDEA!!!! On 13th Jul, 2012 Ben H said:
