| Home > Help Needed / General Tech Chat > speedo drive oil drain | |||||||
![]() 384 Posts Member #: 4215 Senior Member |
3rd May, 2020 at 04:54:30am
hi, looking to put my oil drain in the speedo drive case(i get lots of smoke, really think its my oil drain) and looking for ideas...anybody done this before?do you have pics?
3rd May, 2020 at 10:57:23am
In my experience the problem is not usually the drain, I'd be double checking oil pressure, guide seals, and rings.
3rd May, 2020 at 11:01:32am
Does the smoke go once the oil is warmed through? Because I have had oil drain issues before but only prevalent with cold thick oil, as soon as it’s hot it thins markedly and if it is a drain restriction tends to go away.
3rd May, 2020 at 01:19:25pm
hi guys, i get smoke all the time... have already had the car working with no turbo and at least on idle, no smoke at all(didnt drive it), so i took the old t2 out and got a new gt17(ebay max speedingrod) have smoke for the start again just like with the t2. the whole engine has been rebuilt, about 6-7 year ago. has barely done 3000 miles. so I'm thinking its either the oil drain, or the oil feed sending to much oil? but from what i read, journal bearing turbos, dont need a restrictor... |
3rd May, 2020 at 01:52:30pm
On 3rd May, 2020 Joe C said:
In my experience the problem is not usually the drain, I'd be double checking oil pressure, guide seals, and rings. Check all the ports these if uyou can isolate the oil to one cylinder etc when you say oil pressure, do you mean put a restrictor in the oil feed? i have also been thinking about that option |
3rd May, 2020 at 01:52:31pm
Sorry to say just because its new does not mean it will work just means its new. When you say you have had it running with no turbo I am assuming you mean in a normal aspirated configuration with no turbo fitted at all and you were smoke free? and when you fitted the turbo the smoke returned. You have your answer sir and from my poor knowledge when a car with a turbo is puffing out smoke all the time its the turbo. Own the day
3rd May, 2020 at 01:56:12pm
Mr Joshua, thats correct. that's my thinking also, and since this turbo is new, I'm thinking it might be either the oil feed with to much pressure or the oil drain. like you said , just because it new, doesnt mean its works 100%, but since i have the same symptoms as with the old turbo and the oil feed is the same and the oil drain is slightly worse, i thought they might be the culprit |
3rd May, 2020 at 02:02:43pm
I am at a loss, what is the size of your oil drain? The T3 oil drain was fairly substantial and drained back through where the fuel pump was mounted a nice short route as long as the drain is large than the supply line you should have no issues Edited by Mr Joshua on 3rd May, 2020. Own the day
3rd May, 2020 at 02:04:40pm
cant remember the exact size, but its more of less the same as the t3,18mm if im not mistaken |
3rd May, 2020 at 02:04:44pm
double post Edited by c2_mad on 3rd May, 2020. |
3rd May, 2020 at 02:33:47pm
Then sir I would be looking at the turbo. Own the day
3rd May, 2020 at 03:39:39pm
its not out of the question, but would like to start with the cheapest, easiest options first. anybody on here use a restrictor in the oil feed? |
4th May, 2020 at 04:50:58pm
no, dont fit a restrictor, check what the engine oil pressure is set to, and double check the gauge if fitted.
5th May, 2020 at 04:20:28am
hi joe,thanks for the tips. i do have a gauge fitted. so will have a look and get back with my findings...
5th May, 2020 at 04:20:42am
6th May, 2020 at 06:18:18pm
Most turbo smoke related problems are either insufficient drain, or poor or no crankcase ventilation...which massively effects the ability to drain.
6th May, 2020 at 08:53:30pm
You did put a Restictor in the oil feed? Wasn’t so important on the old T-series, but you can’t have it too large on even the non BB GT series.
Edited by turbodave16v on 6th May, 2020. On 17th Nov, 2014 Tom Fenton said:
9th May, 2020 at 12:52:00pm
He said he has run it without the turbo fitted and had no smoke to my mind that rules to the usual suspects never realised you had to fit a restrictor if you went away from the T3 to another variant of turbo. Own the day
