| Home > Help Needed / General Tech Chat > Verto flywheel machining specs | |||||||
6 Posts Member #: 10673 Junior Member |
8th May, 2020 at 05:13:39am
I have a verto clutch on the 82 998. The flywheel needs to be machined before it gets a new clutch, does anyone have specs on machining? Most Important thing being the depth of the friction surface from the pressure plate mounting surface.
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
8th May, 2020 at 08:14:12am
If removing material from the friction surface the same amount should be removed from the mounting posts (pressure plate mounts) to keep the operating geometry/characteristic the same.
8th May, 2020 at 04:20:49pm
Yeah, pretty standard procedure. I've usually had access to the spec to be sure the friction surface isn't worn too far down, but that info isn't result available in the states heh. |
9th May, 2020 at 10:38:00pm
Can you not just measure it of the outer edge that’s not worn/damaged and use that as your datum point. Get the post height etc. |
16th May, 2020 at 12:16:34am
Yeah, I actually finally took a good look at it, there is pretty much no groove where the disk was, so what ever they take off the friction surface then can machine off the mounting surface |
