| Home > Technical Chat > | |||||||
![]() 1751 Posts Member #: 10190 Post Whore belgium |
3rd Jun, 2020 at 02:57:30pm
that does make it more easy in a way. ( with the nuts) as you can just insert long enough bolts trough do up the nuts and then cut off the exces if i see it correct? ( with the bushes in and so on of course) you can do anything if you set your mind to it...
