| Home > Help Needed / General Tech Chat > Metro Turbo Ignition Coil | |||||||
16 Posts Member #: 11921 Member |
6th Jun, 2020 at 07:28:14pm
Does anyone know what the resistance of ignition coil on the metro turbo is?
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
6th Jun, 2020 at 08:59:56pm
Is the Metro ignition feed ballasted or non?
7th Jun, 2020 at 12:15:12pm
I think it was 12V, 0.7ohms and non ballasted, but i'm not 100% sure.
7th Jun, 2020 at 09:18:07pm
If there's an 12v supply to the coil its non ballasted.
![]() 112 Posts Member #: 10125 Advanced Member Zoetermeer, The Netherlands |
22nd Jun, 2020 at 09:28:51pm
The coil for the electronic ignition is indeed having a resistance less than 1 Ohm. To know if your needs a 12V (non ballasted) or 9V (ballasted) type of coil could be sorted out by checking the wiring loom. If there is a wire from the startermotor coil to the + side of the ignition coil, then it is ballasted. The regular wire to the coil then has a certain resistance or a resistor block is in the circuit, having the 9V coil to work, and getting full 12V power suring starting. |
23rd Jun, 2020 at 03:20:30pm
All metro turbos were unballasted as they were electronic ignition right from the start. |
