| Home > Help Needed / General Tech Chat > Metro Turbo Boost Gauge | |||||||
![]() 114 Posts Member #: 11728 Advanced Member Uden, Holland |
26th Jun, 2020 at 04:24:16pm
Hi guys,
30th Jun, 2020 at 12:21:42pm
It is powered by the boost modulator ECU, which has a boost sensing hose that normally connects to the same line as the fuel pressure regulator sensing hose from the plenum chamber. |
30th Jun, 2020 at 04:36:21pm
On 30th Jun, 2020 metroturbo said:
It is powered by the boost modulator ECU, which has a boost sensing hose that normally connects to the same line as the fuel pressure regulator sensing hose from the plenum chamber. Do you mean this piece? When I touched it softly the green wire came loose. https://ibb.co/J2WDC6n |
1st Jul, 2020 at 10:54:59am
That's the carb vent valve. Nothing to do with the boost gauge, and not worth refitting if it's broken. Just blank off its connection on the carb. |
1st Jul, 2020 at 12:40:09pm
Thanks for that.
174 Posts Member #: 9128 Advanced Member |
1st Jul, 2020 at 11:35:19pm
Supposed to stop the engine running on when you switch off. As you switch off it opens and vents the carb, same effect as flooring the throttle as you turn off. |
3rd Jul, 2020 at 05:16:42pm
Thanks guys.
4th Jul, 2020 at 06:22:44am
Found one already!! |
