Home > Help Needed / General Tech Chat > Canems ecu
TurboTim
Member #: 12041
Does anybody have any experience with this ecu? Looks good on paper just wanted to see if anybody actually uses it?
Thanks
DILLIGAF
Member #: 9128
There was a lad called Stuart think his name on here was SuperchargedStu later changed to TurbochargedStu, who was running this eco. Cant seem to find any posts now though.
shane
Member #: 1246
Lowestoft, Suffolk.
Am I right to think Sprocket ran Canems?
Shane
jbelanger
Member #: 831
Montreal, Canada
Can you provide a link to the actual device you are considering? Also, which setup are you considering: semi-sequential port injection, full sequential port injection, throttle body injection?
The last time I saw something on them was a long time ago and they were using semi-sequential port injection which is not a good solution because you can't correctly trim the different fueling needs between the inner and outer cylinders.
Also, they had patented Marcel Chichak's (starchak.ca) way of doing semi-sequential injection but that relationship was never clarified (by Canems or Marcel) as far as I can remember.
Jean
Edited by jbelanger on 28th Jun, 2020.
http://www.jbperf.com/
hazpalmer
Member #: 9038
Carlisle, Cumbria
Shane
Colin uses I think, and so does Graham with the supercharged small bore.
Colin uses Vems.
Phil.
DILLIGAF
Member #: 9128
This is there website, based in sunny scunny
http://www.canems.co.uk
Edit found him
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=185857
Edited by DILLIGAF on 30th Jun, 2020.
hazpalmer
Member #: 9038
Carlisle, Cumbria
On 29th Jun, 2020 Turbo Phil said:
Colin uses Vems.
Phil.
Vems was the word I missed out! Cheers Phil
