Home > Help Needed / General Tech Chat >
Yoda74
Member #: 11728
Uden, Holland
On 30th Jun, 2020 metroturbo said:
It is powered by the boost modulator ECU, which has a boost sensing hose that normally connects to the same line as the fuel pressure regulator sensing hose from the plenum chamber.
Do you mean this piece?
When I touched it softly the green wire came loose.
https://ibb.co/J2WDC6n
