Home > Introduce Yourself >
shane
Member #: 1246
Lowestoft, Suffolk.
3mm is a massive amount to remove, looking at my notes I didn't log the actual amount removed only the final friction face to post top measurement which was 23.7 mm.
What is actually going on with your clutch in terms of operation? you've only stated " i now cant get a pedal on the clutch at all " Are you achieving full travel of the plunger?
Is the throw out stop set correctly?
Need to ascertain that first before going forward.
Shane
