Home > Help Needed / General Tech Chat > OT - is this DMF goosed or normal?
From a Ford. 110k miles. Didn’t rattle or vibrate; the clutch slipping was the only issue.
https://youtu.be/tU3pbA26Ztw
https://youtu.be/5OMOoIuGibw
I've seen better and worse. If it was my own car I'd probably replace it.
shane
Member #: 1246
Lowestoft, Suffolk.
When I changed mine (BMW E92) it had more play than that and didn't show any symptoms of being U/S. I replaced it tho as it was easier to do the job once and not have to worry about it.
Shane.
Well I just scored a deal on Amazon of a LUK DMF for just over $100 (normally 3x that) so I decided to go ahead and swap it out; especially as a slightly larger engine is going in...
Thanks Fellas!
shane
Member #: 1246
Lowestoft, Suffolk.
For that price its worth it just to cover your time.
Shane
I think there are specs for free play and movement etc...
But really, when you're in there with any intention of keeping it, it's crazy not to put a new one in.
Well and truly knackered.
On my old Mondeo (diesel which are a lot harder on DMFs) the original had the death rattle at 65k miles. And with a lot less play than that.
I replaced it with an LUK one and it was still silent and vibration free at 125k miles when I scrapped the car for all the other TDCi related faults (injectors, high pressure pump, related sensors, etc.)
If you have it in bits and can get an LUK one at a decent price, it's a no-brainer.
EDIT - typo
Edited by Rod S on 22nd Aug, 2020.
