| Home > Help Needed / General Tech Chat > cast iron inlet question . | |||||||
21st Aug, 2020 at 07:54:14pm
Evening chaps ,
Edited by robert on 21st Aug, 2020. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
23rd Aug, 2020 at 08:09:00pm
I have one of the metro cast inlet/exhaust jobbies if its of any use to you, yours for postage.
25th Aug, 2020 at 07:21:54am
Hi shane thank you for the offer , much appreciated , in the end it turns out the spacing is wrong , so it looks like it may be throttle bodies again .
25th Aug, 2020 at 06:19:36pm
sooo what is the head? and how are those ports siamiesed? On 28th Aug, 2011 Kean said:
26th Aug, 2020 at 07:18:18am
Blimey. Single inlet runner into three pots?!
In the 13's at last!.. Just |
26th Aug, 2020 at 07:52:12pm
your right gary but its 2 inlets per three cylinders ...,
13 Posts Member #: 11919 Member Norway. |
30th Aug, 2020 at 05:31:54pm
Almost like these cylinder heads were made for the SU DU6 twin choke carburettors. Best wishes
31st Aug, 2020 at 07:30:32am
I had not seen those before , thank you Anthony . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
30 Posts Member #: 12076 Member |
27th Sep, 2020 at 09:50:15am
Looks like they may line up with weber downdraft carbs ida idf like fitted to the beetle engine,mgmaestro etc? |
27th Sep, 2020 at 09:50:41am
28th Sep, 2020 at 08:14:41pm
it does a bit doesnt it . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
