| Home > Help Needed / General Tech Chat > Threaded block plugs - what material to use? | |||||||
30 Posts Member #: 12076 Member |
5th Oct, 2020 at 09:15:31pm
I've tapped my 1275 block, all the waterway holes, with the goal of using the three front studs and dry decking the block.My question is - what material should I use for where the new threaded stud holes overlap original block and "filler" material? My feeling is brass might cut similarly to cast, enough not to affect the machining anyway?
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
5th Oct, 2020 at 09:37:32pm
From memory (and I would have to check the notes I made from when I did it) I used EN1A bright mild round bar and threaded it with a 3/8 unc split die to get a nice “fitted” thread in the stud holes.
Edited by shane on 5th Oct, 2020. |
![]() 539 Posts Member #: 6807 Post Whore York |
6th Oct, 2020 at 10:42:10am
Use cast iron bar, why mix two different materials unnecessarily? |
6th Oct, 2020 at 05:32:33pm
Hmmm, why - because threading and screwing cast iron bar in is new territory for me, but appreciate it would be preffered. |
6th Oct, 2020 at 07:33:26pm
I wouldn’t be deterred by it, it’s free cutting and easy to work with.
6th Oct, 2020 at 11:03:12pm
I used low grade steel bolts but use a 2-flute mill to ‘drill’ the hole and the same chucking to tap the hole. On 17th Nov, 2014 Tom Fenton said:
