Home > Help Needed / General Tech Chat > Mot problems/handbrake divider
Rammie2000
Member #: 10190
belgium
The diveder on the rear subframe from my saloon is weakend so much that when you pull the handbrake hard enough one side bends open. Rest of the subframe is solid. Thing now is... They pulled it trough on the mot so although I never used it I have to fix it.
Is there a replacement part for this?
Grts
Elfturbo
Member #: 2576
South Staffordshire
Never seen that even on really rotten subframes, sounds like a job for the welder and a bit of fabrication.
HOSS
