| Home > Help Needed / General Tech Chat > Main bearing tolerances | |||||||
869 Posts Member #: 2443 Post Whore Cheshire |
11th Oct, 2020 at 04:45:32pm
Hi all
Edited by Andy500 on 11th Oct, 2020. |
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
11th Oct, 2020 at 06:42:17pm
Depending on which of the specialists you speak to depends on the recommended clearance. There is a massive variance between what the Haynes states and some of the specialists.
Edited by shane on 11th Oct, 2020. |
11th Oct, 2020 at 09:14:46pm
Thanks Shane that’s a great article as well. I’ve just measured all the journals and they come in as 2.0010 for all the mains and 1.7410” for the big ends so I’m pretty confident there within tolerance now after having a mooch on the internet as well for an A+ crank with +10 on the big ends.
12th Oct, 2020 at 07:20:16am
Coming back to this in a less inebriated state.
Edited by shane on 12th Oct, 2020. |
12th Oct, 2020 at 08:02:51am
Thanks Shane, I think the actual standard mains sizes is one of is one of the problems as The HBOL doesn’t state (or at least my version up to 1993 doesn’t)the A+ sizes as different to the earlier 1275 which I think they are?
13th Oct, 2020 at 08:19:36pm
The variance of clearance within HBOL for the mini and metro A and A+ is laughable.
14th Oct, 2020 at 02:11:54pm
I think the bottom line is check the clearance in the block and go fromt there,
14th Oct, 2020 at 04:07:07pm
Thanks Joe.. sorry for the novice question but when you say measure clearance in the block, are you saying with it dry built and then either with a micrometer or with the crank in and with plastigauge? Either option better than the other? |
14th Oct, 2020 at 08:16:45pm
You can install the bearing into the housing and torque to spec and measure with an internal micrometer then subtract the crank journal diameter to give clearance.
15th Oct, 2020 at 09:35:35am
A shane says,
15th Oct, 2020 at 12:54:51pm
Super thanks both really is much appreciated. Joe I was planning on getting new dowels when I order the bearings so thanks for the link as well.
15th Oct, 2020 at 01:19:48pm
It's good practise to lube up the threads.
Edited by shane on 15th Oct, 2020. |
15th Oct, 2020 at 01:42:44pm
👍👍👍 Thanks shane |
15th Oct, 2020 at 05:01:16pm
15th Oct, 2020 at 07:45:17pm
On 15th Oct, 2020 Joe C said:
I like the silicon spray, might steal that! Shane |
