| Home > Help Needed / General Tech Chat > Compression ratio | |||||||
61 Posts Member #: 10810 Advanced Member Kent,medway |
1st Dec, 2020 at 07:26:26pm
Evening all, bit of advice I have a 1293 block with 10 cc pistons, the block face has been skimmed as there was a few imperfections init. What head would you recommend to use for right ratio? Would a standard a series head work ? |
257 Posts Member #: 11017 Senior Member Shropshire |
1st Dec, 2020 at 09:51:26pm
What's your deck height? What crank? What head gasket? |
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
1st Dec, 2020 at 09:53:25pm
Evening,
1st Dec, 2020 at 10:02:48pm
Would it be better to get the machine shop to machine nthe block down so pistons bait flush? |
1st Dec, 2020 at 10:03:16pm
Sorry sit not bait |
1st Dec, 2020 at 10:04:45pm
6581 crank |
1st Dec, 2020 at 10:34:14pm
1st Dec, 2020 at 10:38:46pm
28cc in the head is common, ( 21cc as standard)
1st Dec, 2020 at 11:02:14pm
If the block hasn't been decked severely, you'd get round 8.4/8.2:1 with 28cc chambers on 10cc pistons. A lot depends on what boost you want and how you're fuelling it too. Edited by Steve220 on 1st Dec, 2020. |
1st Dec, 2020 at 11:21:45pm
There’s a video I made on my YouTube channel for working the static compression ratio out, super easy.
2nd Dec, 2020 at 04:52:39pm
Thank you everyone much appreciated!
3rd Dec, 2020 at 08:15:23pm
Never knew this
On 1st Dec, 2020 Turbo Phil said:
There’s a video I made on my YouTube channel for working the static compression ratio out, super easy. https://youtu.be/9Lp-1Rbb4Yo Phil. Own the day
3rd Dec, 2020 at 09:13:13pm
On 3rd Dec, 2020 Mr Joshua said:
Never knew this On 1st Dec, 2020 Turbo Phil said: There’s a video I made on my YouTube channel for working the static compression ratio out, super easy. https://youtu.be/9Lp-1Rbb4Yo Phil. Hope you found it useful. Phil. |
