Page: |
Home > Help Needed / General Tech Chat > Setting the timing on a K1200rs conversion | |||||||
1648 Posts Member #: 9038 Post Whore Carlisle, Cumbria |
28th Dec, 2020 at 04:49:24pm
Is there anything like what you can do with megajolt where you unplug the EDIS and it'll just run at 10 degrees? |
428 Posts Member #: 10128 Senior Member Dorset |
28th Dec, 2020 at 06:51:00pm
On 28th Dec, 2020 chris_rd92 said:
I did venture out today to set the engine to top dead center and to see where the position of the missing tooth on the trigger wheel is in relation to it. But that fell flat on it's face when I realised that I can't get a spanner on the crank pully bolt to turn the engine over without removing the entire cooling system... Didn't fancy doing that in 1 degree weather so I retreated back inside in a bit of a huff... put it in gear and rock the car forward or back if you can't get to the crank pully bolt. |
4300 Posts Member #: 1321 Post Whore Wiltshire |
28th Dec, 2020 at 09:06:29pm
Although the force racing conversion kit I had to also make a TDC pointer. The following might be helpful as reference to check the trigger wheel is roughly where it should be.
Edited by minimole23 on 28th Dec, 2020. On 7th Oct, 2010 5haneJ said:
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
1st Jan, 2021 at 12:27:54pm
I totally agree with that last comment.
15 Posts Member #: 12098 Member |
5th Jan, 2021 at 10:36:10am
Update: I've just got off the phone with John at SC after discussing our options. We've decided the engine is going back to SC to be set up on an engine dyno and run in. Obviously I'm gutted that I have to remove it from the car again as it was such a faff to get in (the thought of removing the manifold makes me shudder), but I'm just glad things are progressing.
5th Jan, 2021 at 10:37:50am
On 28th Dec, 2020 Steve220 said:
Was it a crate engine? As in you just dropped it in, or did you build it from their parts? Trying to work out if there may have been a point where you may have got the timing out. Main things to check are the cam timing and ignition timing. If the cam timing is correct and the ignition timing is right on the gun, then it is down to the mapping. Problem with cold starting is there are SO many variables; crank fueling, coolant temperature multiplier, inlet air temp multiplier, base fueling etc. Although the fuelling on the base map should be enough to at least get it to run, even if poorly on some throttle. Yeah it was a crate engine. They built the whole thing for me. |
5th Jan, 2021 at 03:51:50pm
On 5th Jan, 2021 chris_rd92 said:
Update: I've just got off the phone with John at SC after discussing our options. We've decided the engine is going back to SC to be set up on an engine dyno and run in. Obviously I'm gutted that I have to remove it from the car again as it was such a faff to get in (the thought of removing the manifold makes me shudder), but I'm just glad things are progressing. I'm hoping to have it out by this weekend and ready to collect first thing next week. Kick in the nuts, but fair play to SC for standing by the build and sorting it out. We're in lockdown, what else were you going to spend your time doing?! |
2619 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
5th Jan, 2021 at 08:35:02pm
Could you not of connected your laptop to the ECU and shared the data with John by something like teams or remote access?
Edited by shane on 5th Jan, 2021. |
5th Jan, 2021 at 11:28:19pm
On 5th Jan, 2021 e5tus said:
Kick in the nuts, but fair play to SC for standing by the build and sorting it out. We're in lockdown, what else were you going to spend your time doing?! I had mixed feelings at first, but the way I see it I was planning on putting the car on a rolling road anyway to get an idea of power, but this means I won't have to. Yeah very true! Sometimes I wonder if the mini is preventing me from descending into madness, or if it's pushing me closer to it! |
5th Jan, 2021 at 11:31:30pm
On 5th Jan, 2021 shane said:
Could you not of connected your laptop to the ECU and shared the data with John by something like teams or remote access? Emerald offer a similar service to sort issues like this with their customers? Half hour with the laptop (even if you had to pay SC) is worth while over spending several hours pulling and refitting the engine for a possible potentially easy fix? Shane We spent hours doing exactly that mate. Still completely baffled! What will really drive me insane is if they put it on the dyno and it starts first time! |
6th Jan, 2021 at 07:01:35am
6th Jan, 2021 at 08:47:54pm
I’m certainly curious.
13th Jan, 2021 at 09:48:33am
Hi guys, just another little update.
13th Jan, 2021 at 01:32:22pm
Fingers crossed it’s a simple fix.
13th Jan, 2021 at 03:46:40pm
On 13th Jan, 2021 chris_rd92 said:
also as I pulled the engine on the crane over the slam panel, the crane dropped and took a large chunk of paint off the slam panel, so I'll have to respray that. Not the end of the world as is needed a tidy up in that area anyway, but just a bit of a pain. My crane used to always run out of lift at the exact point I needed 10mm more, beat that panel up so many times! |
Page: |
