Home > Help Needed / General Tech Chat > Low ratios for drop and crown gears
steveg3731
Member #: 10780
Adelaide
Hi all, just wondering what the thoughts are about Minispares/Minisport drop and crown gears.
I'm using 13" wheels for a hillclimb mini and normal turbo setup with a short stroke engine - so about 9000rpm max, but more likely 7500-8000
So grunt off the line is what I want, not top end and looking at 23/30/25 drops and 4.5 S/C crownwheel from Minispares. Are Minisport better - they have semi helical.
Have been told the lower ratios are not that strong - has anyone got an opinion.
4.5 from Minispares appears to be a 14/63
4.6 from Minisport a 12/56
Just want the strongest setup I can get - gearbox is clubman S/C
regards
Steve
shane
Member #: 1246
Lowestoft, Suffolk.
I've ran Minispares gears for some years. abused from the off without issue.
Shane
Many people have destroyed lots of mini sport products over the years on here so that helps make that decision.
I would run whatever set up you need get the gearing down and accept that once in a while you may strip a pinion. A few of the hill climbers seem to with wide slicks now and again.
e5tus
Member #: 10128
Dorset
I don't think the 4.5 is available from Minispares at the moment. MED can do you a SC 4.5 for LSD. If you want semi-helical, swiftune do the Quaife ones, but don't think they go beyond 4.2
steveg3731
Member #: 10780
Adelaide
Thanks all for your thoughts - it's either MED or Minispares - MED only do a 4.2...
e5tus
Member #: 10128
Dorset
MED do a 4.5, does not seem to be on the website drop down, but we've had one before, give them a call
