| Home > Help Needed / General Tech Chat > Dropping the Body on to the Subframe | |||||||
7 Posts Member #: 11879 Junior Member |
9th Feb, 2021 at 06:28:07pm
Hey Everybody,
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
9th Feb, 2021 at 07:07:21pm
Ive done similar recently with a hydraulic scissor lift.
9th Feb, 2021 at 07:19:48pm
If the vacuum module was fouling the starter motor I'd suggest it wasn't installed correctly?
Edited by citykie on 9th Feb, 2021. |
9th Feb, 2021 at 07:42:33pm
"just throw it in and let the customer worry about it"
10th Feb, 2021 at 09:30:50am
Is that Scholar on the A140 near Mendlesham ?
![]() 57 Posts Member #: 11761 Advanced Member Worcestershire |
10th Feb, 2021 at 09:06:41pm
I've not long done the reverse and lifted the body off the subframe. It seemed to take for ever to get it high enough. It came out with turbo , Carb, alternator, starter and radiator all fitted. Luckily my car is not too precious.... If it was it would be quite scratched!! I might put it back in with a few parts not fitted as its a bit of a bugger working alone.
10th Feb, 2021 at 10:49:00pm
Having lifted a body manually in the past I'd have to say the ability to lift/lower steadily and squarely with a lift is a godsend.
11th Feb, 2021 at 08:44:42am
On 10th Feb, 2021 shane said:
Having lifted a body manually in the past I'd have to say the ability to lift/lower steadily and squarely with a lift is a godsend. I couldn't agree more (although I have an engine hoist now so take the engine/box out from the top) but back when I was a penniless student, I just used three mates from college. The only bad part was when I'd finished the repair (mainshaft nut inside the gearbox had come loose so couldn't select gears properly) but when we were lifting the shell back over, the local plod in a panda car stopped and said "it's illegal to dismantle cars at the roadside" and one of my mates responded with "we aren't, we're putting it back together". He was not amused....... Schrödinger's cat - so which one am I ??? |
![]() 428 Posts Member #: 10128 Senior Member Dorset |
11th Feb, 2021 at 04:41:19pm
I've used one to good effect previously. I had removed most ancillaries, less to snag that way.
11th Feb, 2021 at 11:21:13pm
I purchased a used/good condition one of these a few years back for sensible money, the purchase was fuelled by suffering with back problems meaning being stooped over for prolonged periods was very unpleasant.
