| Home > 998cc > 998 KP35 | |||||||
![]() 57 Posts Member #: 11761 Advanced Member Worcestershire |
1st Mar, 2021 at 11:01:14pm
Bit of quick advice needed. I have fitted a small kp35 turbo from the Renault 1500 diesel range with the aim of good low end boost on a stock 998 . The first start up on axle stands revealed huge boost levels with a couple of throttle pumps and without load, which is a bit of a supprise and maybe a concern that the turbo could easily overspeed. What is more of a problem and not something I considered, is that the wastage actuator opens at around 1.5 -2 bar ( way too high for my engine). Is this about right for diesels? The real question, any recomendations for cost effective actuators that operate at around 0.5bar, with the idea of bleeding off to raise boost levels. Ebay seems to have stock actuators with no pressure spec or £100 plus actuators. Is .5bar maybe not popular? I don't want to butcher my T3, but are these actuators available still?
Edited by Jd24-7 on 2nd Mar, 2021. |
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
1st Mar, 2021 at 11:45:58pm
I’ve a stock T3 actuator you can have for £5 + post if it’s any use to you?
257 Posts Member #: 11017 Senior Member Shropshire |
2nd Mar, 2021 at 08:50:49am
As the KP35 run actuator pressure, i'd either change it out for one like Phil is offering, or see if lowering the pre-load works. This turbo is designed to spool quickly on a low revving 1.4TDi. |
13th Aug, 2022 at 01:15:33pm
Little bit of a belated update.
976 Posts Member #: 3228 Post Whore North of the Netherlands |
16th Aug, 2022 at 06:19:35pm
Sounds like a lot of fun!
Dazed and Confused.... |
17th Aug, 2022 at 02:33:03pm
It's quite possible that some fettling of the wastegate orifice would achieve the same result, but I went with the external gate as it seemed to offer the best chance of success and minimal risk. As a downside, its a bit of a pain to fit, exhaust in/out etc, but function wise it is spot on. |
10 Posts Member #: 12185 Member |
18th Aug, 2022 at 11:45:18am
On 16th Aug, 2022 Yo-Han said:
Sounds like a lot of fun! Seem to remember people on here drilling out the wastegate hole to help against overboosting/boostspikes(?) not sure if that would in your application though. This was usually on the GT20 turbos. Take a look at Brett's old thread or Nicks. They opened up the hole in the waste gate |
1 Posts Member #: 12191 Junior Member |
5th Sep, 2022 at 08:53:00pm
i send you a message Jd24-7
