Page: |
Home > Technical Chat > | |||||||
1648 Posts Member #: 9038 Post Whore Carlisle, Cumbria |
6th Mar, 2021 at 08:24:35pm
On 6th Mar, 2021 TurboTim said:
May have found a small air leak at the plenum. To be honest it pulls fine when it comes in boost so may be a wrong reading on the wideband? There is also no smoke when it does boost and reads rich. Dashpot moves freely. What would be a leaner needle from a BDD to try and work from? Use the minty lamb su site to compare needles. BDD is standard metro turbo needle so I don't see how it can be so rich all the time. The air leak would probably make it run lean rather then rich |
Page: |
