Home > Help Needed / General Tech Chat > Battery cable
vestfoldracer
Member #: 12113
What is the best mm2 cable for battery to use?
I have the options of 16mm2 and 35mm2 at the local shop.
Dose it make any difference for turbo setup?
Prefer to run the 16mm2 for the weight. 35mm2 is heavy!
Living in Norway so ordering a standard cable takes time from UK.
Thanks! *smiley*
Really you'd just be using welding cable, should be readily available in a lot of places.
I'd say though that 16mm^2 would be plenty for a Mini, but you could step up to 25mm^2 if you wished.
35mm^2 would be massive overkill.
But any welding supply shop should have various sizes of cable
vestfoldracer
Member #: 12113
Thanks for information!
