Home > 998cc >
wilsonc001
Member #: 11333
In case it's of use to anyone else, if you're using the standard A+ head (CAM4810) the BDD needle mentioned in the original post is too rich on boost/under load and I've found it too lean on light throttle.
The BDL needle seems to be a very good starting point. A little lean still on light throttle but almost perfect under load maybe just a touch rich.
Once I get mine on the rolling road, I'll update the thread with what's found.
Home > 998cc >
