Home > Help Needed / General Tech Chat > Metro turbo cutting out
slim_shadyuk
Member #: 703
Plymouth, On the floating skip known as HMS Albion
Hi i've just recently purchased a metro turbo which im planning on using as a donor for my mini.
The engine has been recently rebuilt and has the following fitted, 1.5 full roller rockers, block bored to 1293cc fitted with omega pistons, avonbar phase 2 turbo cam, minispeed turbo head and rs turbo intercooler.
The engine idles just fine but when placed under load above 2,000 rpm or rev'd hard while stationary it cuts out as if suffering from fuel starvation. The clear fuel filter just before the pressure regulator appears to have air trapped in it as its only half fuel of fuel even though the pump is running.
The previous owner said he didnt adjust the pressure regulator and that the fuel kept becoming blocked!?
Any advice would be appreciated!
Lee
Whats going to break next!?
Turbominis Worst Advice winner 2006, get in
Do a search for tee-piece trick on this site. Highly likely that'll solve the problem.
slim_shadyuk
Member #: 703
What would i do with a tee piece though!? how would that sort it and where does it go?
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2103
As I suggested, use the search button on the upper left side of the page... *wink*
The above will explain what usually happens, why it does what it does, and what you can do to cure it with a simple 1/4" tee-piece.
slim_shadyuk
Member #: 703
Opps my apologies i was a bit hasty in reading your original post! thanks for the heads up ill get onto it right away!
ditch the phase 2 cam with 1.5 rockers
link below.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=6133
slim_shadyuk
Member #: 703
aahh interesting ill give that a try! and tee piece trick worked cheers dave!
