Page: |
Home > A-Series EFI / Injection > | |||||||
1300 Posts Member #: 829 Post Whore essex |
10th Oct, 2021 at 09:05:48pm
i have got to the bottom of it i had a spark and i had fuel but would not start it turned out to be the injector (SPI) model had stopped work what i did was remove the black plug and wired a LED lamp to the black plug on the loom so when you cranked the engine the lamp flashed so i removed the injector to find it was blocked with shit blow out with air line put it all back turn the key and it started straight up 1293 Turbo mini
Page: |
